2016 sTouring 5-door with 44k miles.
I need an alignment to correct toe wear on tires. I also have a 'cracked' CV boot that should be replaced.
Should the alignment be done after the CV boot is replaced? Or it doesn't matter?
Also, I need to replace two same end of the car tires. Should I save the alignment until after I get the two new tires?
Thanks!
(Back story on the tires - Front and rear are mismatched because I had to replace the rear tires 4k miles ago after one got destroyed against a curb. The front tires, with 12k miles on them, are showing toe wear (particularly on the driver's side) that needs to be corrected. Those are the tires I'm thinking of replacing to match what is on the rear while the rears are still relatively new.)
Thanks!
