1161 - 1180 of 1214 Posts
@Fonmin Yang : Uninstall all tweaks via AIO (red checkboxes). Afterwards open AIO, go to top left "install options" check the option "apps to ressources", choose your tweaks, compile and install them. This way your resources folder will not get installed any tweaks (and has more space left). All tweaks will be installed to the ressources folder, which has a lot more space.
Tristan-cx5
i mean i have perform full system restoration , but i am still getting full rootfs error message when installing my aio tweaks, any file in rootfs is safe for me to clean up in order not to get full rootfs in my cmu?
I do not know much about that. But please perform the uninstallation (all tweaks red in AIO) and check your root afterwards. Perhaps the full system restoration did not delete all tweaks. If that solution works, all is good. Otherwise please contact @Trezdog44 (AIO developer).
Hi everyone I update FW 59.00.545 to FW 70.00.100 and install AIO 2.8.4-1.
I don't use android auto but I can use speedometer and video player.
I want to use android auto . What should I do to use it?
Have the new hub and cables installed should do the trick.
@dammy89 : I've never downgraded myself. Only read a lot about it. From what I read, you have to look at the firmware update procedure manual/pdf and then change the file installation order (1st/2nd file to install) for performing a more safe downgrade. Thats it.
Hello, i have a problem and i havent found a solution...
I have 2017 mazda 3 GT. I have been using android auto for a while but i have a problem when using maps/waze and listening music on Spotify... every time maps/waze makes an animation or a turn, the music starts to lag so much, but it doesnt happen when only using music.. i have a galaxy note 9 with Android 9.0. Original USB cable.
Have anyone the same problem? Is there any solution to this?
Enviado desde mi SM-N960U mediante Tapatalk
Pretty Cool Dude
Unfortunately this is a pretty common problem. Using official AA will not have this problem but you have to pay for the upgraded usb unit and you also lose the touchscreen ability.
Can the touch screen ability be turned back on with AIO tweaks? We're working on getting the serial connection running (2019, so afaik I can't roll back to older firmware) to install the tweaks I had on my old Mazda, including the access to the touchscreen when moving -- does that bring it back for the official Android Auto?
No, the AIO tweak "touch while driving" does not work at official Mazda Android Auto (AA). There is no way to enable touch at all for official Mazda AA. But for official Apple CarPlay (CP) touch while driving can be enabled via AIO touch tweak. Touch while car stands still works from factory for official CP, but not for official AA.
There's a 2015 I'm looking at buying, the current version on it is 33.00.500. It doesn't look like the AIO mod supports that version. Am I able to update it to a newer version myself and then install the mod?
Pretty Cool Dude
It will support V33 but i recommend upgrading to V55, installing ID7 tweak, and then installing V59.
Hello,
I need to make serial access. In MZD-AIO-TI in Autorun Recovery I have:
ID7_recovery scripts
Auto WiFi AP
SSH Auto ADB
Dryrun Script
Recover Via Serial Connection
What shoud I check? I don't know if I need:
Auto WiFi AP - what is it?
SSH Auto ADB
Dryrun Script ??
Please help me :)
