I need to disable the touchscreen, and would love to go the software route using this fix, but it seems the link is dead now. Does anyone have this file mirrored or hosted somewhere else? I really don't want to pull apart my dash to physically disable the touchscreen.There is an issue that effects a pretty significant number of people where the touchscreen is broken and just kind of goes crazy so I made this for anyone effected by that issue
This will completely disable the touchscreen all the time: http://nots.mazdatweaks.win.
To re-enable the touchscreen you just run this same installer again, it will detect whether the screen is disabled or enabled and do the opposite.
also I got a nice stable Speedometer v5.3: http://speedo.mazdatweaks.win
- Speed readings are no longer delayed
- Shows "---" for invalid values
- Long hold multicontroller tilt down (3 seconds) to show/hide the speed bar
- Batt SOC will show err if i-stop error
- Fixed some number sizings
I am going to take a break from the speedometer until I finish up the next AIO version but I do have a few goals for future speedo development.
Hi, unfortuately no I didn't. To be honest I tried everything you mentiond here, eventually I felt I needed to take a break. Hoping that maybe when I comeback to it, I would find a solution.Hey I have this issue as well. Did you ever figure it out?
I have tried everything I can think of.
New cable
clear cache on the phone apps: Android auto, google play services, maps, spotify
disabled battery optimization on the phone and specifically whitelisted spotify, since I thought this was throttling background apps
Sorry, despite editing twice I still mistyped the firmware version. It was 70.00.100A. I corrected it in the OP.Really? Usually/in my tests after the update to FW 74 you can not install any AIO tweak via USB, if you use your method, as the installation of FW 74 will delete the ID7 tweak. How did you do it?
You'll need to follow the instructions for a serial connection on mazdatweaks.I want Apple Carplay to touch the screen while driving, how can I do this?
My setup by now:
1. MZD F/W: 70.00.100A.
2. Install Apple Carplay USB Hub.
