No. Factory wiring colors change between vehicles, only aftermarket harnesses use the same colors. Wat you want to do is tap into the orange wire on the factory side (not on the metra harness) with the speed sense wire from the HU harness. If you want the screen to dim with the headlights, you'll want to connect the orange wire from the HU harness to the Orange wire on the metra harness, IF you're vehicle supports that feature at the radio. If it doesn't then tap the HU Orange to parking light positive.
