you could just use one of the back-up lights for the extra brake light.
Just swap out the brake lights to brighter ones or even led ones. Adding more of a low light bulb will still yield a low light.How do you use the backup lights as extra brake lights? I thought it was just me until I followed my daughter, she also has a 2014 Mazda three and I thought that the brake lights were very inadequate and they're hard to see from directly behind.
Is your daughter's car tinted as well? If so how dark? Since the sedan's third brake light is on the inside, if you tint over it it'll decrease the visibility a bit. I've actually been behind a couple of mz3 with the non LED brake lights and they're not too bad.How do you use the backup lights as extra brake lights? I thought it was just me until I followed my daughter, she also has a 2014 Mazda three and I thought that the brake lights were very inadequate and they're hard to see from directly behind.
I know what you mean, I don't know what mazda was thinking with the small night/brake light. At least for the non-LED models. The surface area is very small.How do you use the backup lights as extra brake lights? I thought it was just me until I followed my daughter, she also has a 2014 Mazda three and I thought that the brake lights were very inadequate and they're hard to see from directly behind.
I'm looking to add bright leds to the trunk area and upgrade the current lighting. Not just add low lighting. These lights I want to add are brighter then stock lights but I want to increase the area the tail lights cover. I have a good idea of how to fit the lights but not how to wire it. Also I'm not moding the backup lights to do this. I'm adding a whole extra wiring for the brakes. If someone has a trunk wire guide for the sedan.Just swap out the brake lights to brighter ones or even led ones. Adding more of a low light bulb will still yield a low light.
Pg 215 and 217 for the wiring diagram for the brake lightI'm looking to add bright leds to the trunk area and upgrade the current lighting. Not just add low lighting. These lights I want to add are brighter then stock lights but I want to increase the area the tail lights cover. I have a good idea of how to fit the lights but not how to wire it. Also I'm not moding the backup lights to do this. I'm adding a whole extra wiring for the brakes. If someone has a trunk wire guide for the sedan.
Awesome thanks that will help a lot. I'm gonna have to do some research on the whole process and find a good time to do it. It's currently - 20 c out so I might wait till things start to warm up to attempt thisPg 215 and 217 for the wiring diagram for the brake light
