Has anyone looked into adding the Mazda oil cooler delivered on cars going to Mexico?
It fits under the oil filter and is plumbed into the cooling system. Searching I found P/N 14-310A housing that supports the filter and the cooler P/N 14-700. Mazda seems to use the same part number for many engine families..... Also would the oil cooler be used on the CX-5 with 2.0 liter engine?
Something like this for our engines:
http://www.torontomazda3.ca/forum/showthread.php?35698-How-to-2004-2009-European-spec-oil-cooler
5/17/14 Update after looking at the car: There is a cast bracket supporting the drive axle that surrounds the oil filter housing. My current thinking is it may have to be a sandwich adapter at the filter with oil lines running to a traditional cooler in front of the radiator.
Thanks for any info.
Rob VN
Rob VN
