1 - 13 of 13 Posts
Adding a Subwoofer. 10" or 12"
Well, I have read and reread the sweet plug and play write up @wcarman1 did http://mazda3revolution.com/forums/2014-2017-mazda-3-skyactiv-how-guides/65953-bose-stereo-subwoofer-install-plug-play.html and it makes me really want to get a subwoofer now. I like that everything I could need is currently available on amazon. The write up is simple but offers all the needed information. SO that leaves me with wondering if I should get the 10 inch version or the 12 inch version.
what size subs are you guys using, and please share your thoughts. I would like to purchase tomorrow so I can get a nice Monday delivery.
10" box dims:13.3 x 18 x D1 8.9 - D2 5.9 (in)
haven't found the 12" dims yet
Powerbass 12" with the loaded ported enclosure
It's pretty big @ 21 x 17 x 16 inches but fits perfectly fine in my sedan with plenty of room to spare
I doubt it would fit good in a hatch, maybe just barely since it's a foot shorter in length
I really like that setup. Been thinking about doing something similar. I've always had systems that utilized wasted space instead of subs in a box in the back. Maybe because I'm older now I'm reluctant to yank the spare completely out. It was a no brainier before lol
Yeah under the lid is my spare, tool bag and jack.
My subs have big magnets so the "boot" floor is actually raised about 100mm from OEM.
When I bought my Mazda 3 with Bose audio, I was really surprised that they have not included a subwoofer in the boot. My old 2004 Mazda 6 was with Bose audio and it had a factory subwoofer placed in the spare tire. Very clever idea for not wasting additional space for subwoofer enclosure and it was very effective indeed. I'm missing this punch from the sub in the Mazda 3.....
It look awesome! I want to build something similar, do you have build log somewhere? I check the boot but the floor's not flat. How do you mount everything? Thanks!
No build log unfortunately but box was quiet complex to build to put the subs in that position and keep the spare. If I made it as a 1 piece box it would never have fitted so is it 3 pieces that bolt together once fitted.
Mazda 3 Lover
have you been able to hook your sub? did you hook it with an amp to the default head unit?
Hi ianik777,
I hooked mine up to the default headunit line level outputs - the kicker sub I have under the passenger seat does Hi to Low level conversion. I have a pic of the wiring example in this thread: http://mazda3revolution.com/forums/...hs8-underseat-sub-db-test-2014-mazda-3-a.html
Since that first post of mine, I have added Anderson connectors to the +/-12 supplies and also XT60 connectors to the line level wires. So now I can chuck in a 12" sub into the boot when I want; just disconnect from under the seat where this 8" sub is and throw the sub box wiring wire over the backseat to connect up. I only do this when I use the car and going somewhere where I wont require the use of the boot.
I can tell you that it is ridiculously loud - this is a ported box also. I haven't put my dB meter on it yet but will post a video when I do.
Cheers.
1 - 13 of 13 Posts
