Hi, anyone with a good solution for fixing ABS/TCS lights coming on in their Mazda3?
I have a 2nd gen 2009 Mazda3 with 50,000 miles on the clock. A couple of weeks ago the ABS and TCS lights came on at the same time. After a few days the lights went off, and after another few they came back on again. This happened a couple of times, now the ABS light is on constantly and the TCS light comes on about 10 seconds after starting the car. Brakes work properly.
I went to see my mechanic for a diagnostic test and got these fault codes:
C006A95 Acceleration Sensor / Incorrect Configuration
U300316 Battery Voltage / Circuit Voltage Below Threshold
U042862 Steering Angle Sensor Module / Invalid Data Received
C00201C ABS Pump Motor Control / Circuit Voltage Out Of Range
U041592 CAN-message: ABS/ESP Control Module / Invalid Message
My mechanic couldn’t pinpoint the problem based on the fault codes and suggested to start taking things apart. Any ideas how to fix this?
Before you start throwing money at it without knowing what the problem is, have the battery checked. If the system is operating at a voltage that is insufficient for proper sensor operation you'll get a bunch of codes just like that.
Will try that, thanks.
