I just ordered the z23 brake pads for front and rear... will eventually do the CS BBK for the front and full z23 w/rotors for the rear. Started by upgrading from the stock 215/45/18 et45 on touring tires to a 235/40/18 UHP all season on 3lb lighter 18x8 et40 wheels, all for only $1200 total out the door with tire certificates, nearly identical to stock total diameter and sidewall.
I only had the stocks on for less than a week, the difference is night and day, Mazda really shouldn't have cut cost in the wheel/tire dept. so much! Less weird dead center steering feel, better handling with much better quick maneuvering response, more absorption of rear torsion shudder over bumps and yes... improved braking, as when you have better grip the tires won't let loose triggering ABS, it's really the first step in better braking!
[/QUOT
Planning on increasing width and circumference slightly on the 19’s then matching circumference on the 18’s (increase sidewall profile). Speedometer will then be recalibrated once its all done. Not in a rush, waiting till these stocks are used up. A better contact patch with minimal weight loss/gain, in order to gain that dropped (wheel gap) look in the summer and more pothole friendly bump resilience + clearance in the winter. 🤞 😝OK, but he would have to run 235/30/19's to keep the same overall diameter, all to eat up 1/2" (half the additional wheel size) and would be pretty spendy for just 1/2" less gap, but that's just me looking at the value quotient. I guess if you can afford a nice set of 19's and the more expensive tires and have separate winters that works too... Looking at tire size calculations could prob do 235/35/19's I guess... But my original comment was in regards to what you had been saying, it's the width that gives you additional contact patch/traction, regardless of wheel diameter or sidewall ratio.
