So after waiting and searching I finally found sensible and affordable rotor and brake pad upgrades for the AWD Turbo. Now here is the reason I say sensible and it was my reasoning and just my opinion as well as my cash...If you don't agree that's fine because its your money as well so do as you wish, as we all should in life, IMO. My requirements were as follows...
1. Same size as stock so it was easy to change back to OEM at any time.
2. No need to use shims or spacers (most* big brake kits require wheel spacers due to new caliper size)
3. Ability to size rim up or down at change of seasons, (I live in snow belt, larger rotors would limit smaller rim to accommodate a larger tire profile)
4. Ability to use the stock spare tire in the event of a flat, (larger rotor and wheel spacers would leave me stranded waiting for a tow)
5. Less Brake dust and quieter/smoother braking
6. Shorter braking distance and quicker response at higher speeds
7. Don't br the bank, Its only a 300lb car with less than 300hp, No NEED for 6 puck calipers,
I went with...
1. SP Performance Drilled, Slotted and Vented Silver ZRC coated front rotors using Carbon Ceramic Pads / (F26-810-P) Rotors and Front pads (CD2218)
Ordered directly through SP Performance / Under $250 Delivered
2. PowerStop Drilled and slotted Silver ZRC coated rear rotors using Carbon Ceramic Pads as well / Z23 EVOLUTION SPORT BRAKE UPGRADE KIT PN# K8334
Ordered Through Rock Auto / Under $140 Delivered
(6-6-2022 edit added #3 below)
3. Upgraded from Dot 3 fluid to full synthetic Prestone Max Dot 4 brake fluid.
All less than $400 for everything on all 4 corners. Wanted to add stainless braided lines but still can't find them.
Got to be able to slow it down quicker before I make it quicker LOL!! I just think paying 1300+ for 2 wheels w/6 pistons is nuts! then you have to use spacers and your screwed if you need to use a spare and that's just for the front and you are stuck with their pads for life. All that size and $$$$ to stop a 3100lb car, LOL this should improve braking astronomically as well as less dust, noise, weight, heat and better looking and less rusting then the OEM's.
These hit all the marks and definitely exceeded my expectations. Definitely a worthwhile upgrade and brings the braking up to the level the Prem + turbo 3 should have straight from Japan….now onward.😝
(2/13/2023) Update
The brake changes made a huge improvement in braking at speed, night and day hands down. I have now upgraded tires to Mich Pilot 4's as I had planned to do after wearing those Garbage Turanzas out. Great tires little heavier but much better grip and more substantial sidewall.
Added some VHT Caliper paint 🎨. Couldn't help myself. Latest still a tad more vinyl to finish/blend the Side. Looks way better in person.
I went with...
(2/13/2023) Update
