1 - 16 of 16 Posts
Here is the new 2019 BP Mazda 3 OWNERS MANUAL for North American Market.
Close to 600 Pages.
https://s3.amazonaws.com/tsd.mazdausa.com/Mazda_Owners_Manuals/2019/2019_Mazda3_OM.pdf
Mazda Navigation SD Cards will not be Standard Equipment, but must be bought as a Mazda Accessory from Dealer.:surprise:
Couple of things worth Noting..
BE VERY CAREFUL with Wiper Arms or Wiper Blades, DO NOT Place ANYTHING Under them, like pieces of card or paper, or releasing UP to clean.
Why, well like most in this all new car almost EVERYTHING is monitored by ECU/BCM/PCM Including the Wipers and IF they have to be reset, this can ONLY be done by using Mazda Diagnostics MMDS/MDARS to reset and re-train the Wipers.
Also for those technically interested, the Ford/Mazda IDS used by Mazda Dealers for the past 20+ years and some Independent Garages or Shops can NO LONGER be used from all new Generation Mazda's made from the BP Mazda 3 ON-WARDS.
This completes the divorce 100% from Ford as Mazda has been using the Ford IDS under agreement while some products are still jointly made, the final product is the Mazda BT-50/ Ford Ranger which finishes production at end of this year.
The current Bosch VCI or VCM II can still be used for Pass-Through to PC, BUT the all new for Mazda MMDS/MDARS .Msi (BOSCH) user file is installed on Dealers Tech PC, but interfaces LIVE via Cloud and Mazda Distributor/Dealer Portal Access Login.
So, no repairs for diagnostics and coding of modules, Keys, Wipers, all i-Activesense, PCM can be done independently by anyone other than an Authorised Mazda Dealer.
How PAID access will work is yet to be confirmed.
*The Electrician*
Thanks, for giving me more reasons to not purchase a new Mazda........
Mazda "E" Division
Since OBD-II was in 1996. There's been some concept talk on the new standard.
OBD-III ?
faults are picked up by a monitoring technology and reported to a regulator and the vehicle owner is then directed to get further testing and possible repairs.
on-board cycle of fault detection, notification and follow-up testing and repair (concepts)
Just an update - 2019's are still on the OBD2 standard
Yes seems the wipers need to be moved into service positions before raising them, I've attached a .pdf file showing this, please note the file extension needs to be renamed to .pdf from .csv before viewing.
Mazda "E" Division
The design is similar to Mercedes - its tucked away under the hood. You can do the wiper procedure or just open the hood.
Discussion Starter #11
OBD III has been talked about since 2000, and has never extenuated.....perhaps in another 10 years?, OBD II has served well and can handle all of the AI stuff in the pipe AFAIK.
As far as electric Wipers are concerned in all new Mazda's, the YT Video shows how to reveal and expose them and how to.
THIS IS NOT, Repeat NOT the procedure 'if' Owner or Dealer puts them out of alignment by moving or forcing them or placing cardboard signs under the Wiper Blade/s, this can ONLY be re-calibrated via MMDS/MDARS @ a Mazda Dealer service Department.
Why would the car's elect. systems care about the position of the wipers or if they have been disturbed?
Note the key fob batteries are now the higher capacity CR2032 so should last longer.
The manual doesn't seem to cover the menu system and personalisation features. Where is this explained?
Reactions: PeteDK
Wait, what if someone on the parking lot tries to leave me a note and tries to put it up? He'll break my wipers? Do I read it right?
1 - 16 of 16 Posts
