Hello All
I recently purchased a used 2018 Mazda 3 Touring Hatchback and after sitting in the garage for 8 days it started having problems starting. I just bought it from a dealer a bit over 2 weeks ago and the first week it was running fine without any issues. On Sunday I tried starting the car and it sounded like it was going to start, but it didn't. I've been researching as much as I can on the subject, including the search bar in the forums, but I couldn't find the exact same issue and similar issues were for older models so I'm not sure if that would even be relevant.
I've had to use a jump starter 3 times and when I do it starts right up without issues, though the engine does seem to have a slight hesitation to start. I had a family member use a voltmeter to check the battery and it said it was at 12.71 volts after having driven it close to 6 hours (daytrip) and it also said the battery was at 80% capacity. Also, though the car doesn't start the lights seem to be normal brightness and all electronics in the car work fine.
One of the videos found on Youtube was of a guy saying there was a starter fuse that may need to be changed at times when people thought it was a bad starter/locked engine?
I'm not mechanically inclined (I can change light bulbs and fuses, small stuff like that), but I wanted to at least get an idea of what it could be and see if it's anything I can easily fix myself. Car is in Texas so the weather is somewhat mild.
Please let me know if there's additional details I can provide. I certainly appreciate any help I can get!
Thank You
-check the resting voltage after the battery has sat for a few hours/overnight (should be 12.5v+)
-check the cranking voltage when trying to start the car (should not fall below 10v)
-check the charging voltage when running (should be 13.5v+)
Worth it to clean the battery contacts as well, and maybe to have the battery charged & tested at an autoparts store (not sure if they're open right now...)
It sounds a lot like a battery issue to me, but it could be a loose/dirty battery terminal connection
What's the battery voltage if you try to start it without the jump leads?
I honestly don't know, sorry.
the battery contacts look clean. I contacted my mechanic today and he said it's probably the battery as well and based on what you guys are saying looks like I'll be buying a new battery soon.
I'll chime in again after taking it to the mechanic with the final resolution just in case it helps someone else
Thanks for all your help!
You guys were completely right, had to replace the battery. Car ran fine on the way back home.
Thanks again for all your help!
