If you mean replacing the low end halogens with the high end lighting system, you might want to check the co$t before you get to far into this.....:surprise:Hey guys! Does anyone had done headlight retrofit on the 2017 that comes with halogen bulb? Bi-Xenon or lenses swap? Thank you!
chutoyy thank you for posting this pictures. I have halogen headlight that I have installed Morimoto kit. I believe the 17 GT has better lenses since they carry the LED headlight. When did you do that? Did you do by yourself?Did lens swap on my OEM bi-xenon w/ LEDs.
Clear lens swap isn't worth it.
This is OEM w/ clear lens
This is OEM w/ HID
I already got the HID Morimoto kit that improved a lot my light output, but I think it can get better. That's why I am doing some research to do lenses swap.Lenses and projectors won't help much without bulbs that produce more light.
For a simply brighter slightly whiter bulb you can still use halogen and have a great result.I'm interested in getting better bulbs, didn't want to start a new topic for it. Seems to fit here.
I have the standard halogen projector. Wanting to put Xenon HID or LED, but don't want to change anything but the bulb. Also of course don't want light scatter or to blind oncoming traffic. Just would like a slightly brighter, whiter light.
Is that possible? And if so, what are some recommendations on bulb?
Yes it is possible. There have been a number of discussions about this lately. Use the search function to find them.I'm interested in getting better bulbs, didn't want to start a new topic for it. Seems to fit here.
