1 - 2 of 2 Posts
I find the operating logic of the console settings a bit awkward. Some you toggle, some you push etc...
I need to do some definitive testing in case I missed something but,
1. The clock doesn't change for daylight savings time. Is it supposed to?
2. Sometime I set, 'Display Off and only display clock.' but it doesn't stay that way after my trip and it reverts.
Any tips appreciated.
For the clock....there is a setting in the function that you can set to DST or manually. Also the clock should change automatically depending on timezone based on GPS. I don't know if the setting and function is dependent on having a nav card or not. I have a nav card
Regarding display off...I believe that is not permanent and you need to set each time...probably because Mazda wants to remind you that you are getting into a Mazda :)
1 - 2 of 2 Posts
