1 - 9 of 9 Posts
Battery died for some reason (maybe me leaving something on overnight) Called CAA and dude battery jumped it. After he left I notice both left & right signals, emerg. flasher and the Heater fan not longer worked.
I looked under the hood today (Superbowl Sunday) every fuse was good.
If anyone has a reason for this today please advice. Going to Crappy-tire tomorrow otherwise. Hard to drive in -40 weather with no defrost.
Discussion Starter · #2 ·
New here, so do not know how to edit this post. So... forget to mention the signals flash real fast but all the bulbs work ??
I doubt the battery will help. This is an electrical problem, not an electronic problem.
Check your fuses again. You may have one that is damaged or blown but appears fine. Check the owners manual. It tells you what fuse powers what equipment. Hard to believe, but its true!
If you care about your car even slightly, please don't go to crappy tire. That's where mechanics go to die from stupidity.
Mike C is the winner. All fuses were good. Next step: disconnect the battery for 10 minutes... BINGO
Heater fan all signals, high beam came back to life.. Thanks
I had the same issue after replacing a dead battery. Fuses were fine. Disconnected the electrodes for almost exactly ten minutes and everything appears to be back to normal. I am wondering if for some reason temperature is a factor. Not -40F but it was a pretty cold day here in Maine.
This thread is a life saver!
I live in California and replaced my battery about 3 months ago.
Unfortunately, I forgot to turn the light off a few days ago and the battery was dead when I tried to turn it on this morning. My roommate gave me a jump start but I had the following issues:
1. Fan was not working at all (note that the AC was working but the fan was not).
2. None of the blinker lights (front or back) were working.
I drove to the dealership and they said they'd have to run a fool diagnostics and also couldn't see me that same day. I scheduled an appointment for the following day.
When I came home, I checked all the fuses and none of them were blown.... After finding this thread, the solution of simply disconnecting the battery, waiting 10 minutes, and reconnecting it magically fixed everything!!!
Did you disconnect both battery terminals or just one?
Removing either of the terminals would completely shut down the 12v circuit equally well. Usually, folks remove the negative side.
1 - 9 of 9 Posts
