Hi.
I know there were many discussions about theese kind of things, I've searched the forums but I didn't find any solution.
My problem is that sometimes when shifting from first to second there's a very annoying crunchy, metal on metal feeling. It is something similar to what you feel, when your synchros are worn, and you are grinding gears. My car is a 2016 Mazda 3 Takumi, and it's been doing it from the first day, so, I don't think there's a problem with the care, more likely, I'm doing something wrong, but I don't know what, and it is driving me crazy.
I tought, maybe I'm not pushing the clutch all the way in, but I am. When it happens, I always check my left leg, and I can feel the floor. Then I thought, maybe I'm shifting too fast, not giving enough time for the synchros to do their job. But this is not the case either. I handle the gear stick relatively smoothly, every time pause for a moment before I put it in the next gear.
My problem is, that it happens only sometimes, and I can't figure out in what case. Let's say from 10 shifts, 9 are very smooth, the shifter almost goes into gear by itself, and then at the next shift, it grinds (still going in smooth, but crunches at the end). Am I doing something wrong, or is it normal, and I should let it go?
P.s: When I shift from first to second, and it grinds I sometimes stop and try to do the same shift, at the same speed, at the same rpm, so maybe it happens again, and I can find a pettern, but the next shift is always smooth
It is random.
Thank you.
Thank you.
