1 - 20 of 26 Posts
Hey guys, I've started doing my own oil changes and I've been thinking about purchasing some rhino ramps. I've seen quite a few reviews saying that the ramps break easily but it has been mostly with very heavy cars. What are you guyses experience using it with our style of Mazda's?
Thank you in advance for your replies!
Spend the money for Race Ramps.
Been using them for years and never had a problem. Rhino ramps, like anything else, will break if you do stupid things with them. Most of the breaking issues that I have seen involve some idiot driving off the side or the end of the ramp, causing the ramp to flip up and around and crushing it sideways. If you know how to use them you won't break them.
I use ramps for oil changes also and I can say you won't regret the investment. Just be sure to lign them up right before driving the car on to them. I usually kick them in place. If you give it too much gas, you'll drive over them completely. That's a good story.....
But short version is get them and be careful.
They work fine on a 3. There's just enough ground clearance in the front to get the front end up without scraping the lower bumper cover.
2015 Mazda3 iGT
I’m about 4 inches off the ground and have a front lip spoiler. Those ramps don’t have enough of an angle for me to clear them unfortunately.
Been using Rhino ramps for years when changing oil, never had any problems. Found mine on Craigslist for $25, I seem to recall. I also place jack stands under car, as a safety measure.
Let us know what you think. I don't regret buying mine for a minute. I also have a large floor jack and Jack stands, but the ramps are so much easier when I'm doing a quick job like an oil change or undercoating in the fall.
Same. I have to jack up a tire and slide the ramp under for the front wheels.
I can reverse up the ramps for the rears though. It's less nerve racking to just use the hydraulic jack though.
True. I have Rhino ramps. They're a lil too steep for the mildly dropped 3 & its front overhang.
2018 GT hatch, manual
One thing I would add here is that it is only ~$10 more to get the max version that has a higher weight capacity and wider track. While the lower version is enough, it gives me some piece of mind to have the additional capacity, and the wider ramps make it easier to not get too far off center if they aren't perfectly straight.
Discussion Starter #14
I was thinking the exact same thing! For $10 it's a great price.
Used Rhino Ramps for about 4 years now, but, with a set of Aux ramps that I built (saw the idea on a BMW site) It worked a Treat for my X-Type Jag as well as the Mazda... Rhino + Ramps (3).jpg Rhino + Ramps (4).jpg Rhino + Ramps (6).jpg Rhino + Ramps (7).jpg Rhino + Ramps (2).jpg Rhino + Ramps (7).jpg
Discussion Starter #18
My Rhino Ramps often are used on a 2018 F350 Dually for extra space to do oil changes. No issues. A 2006 Sequoia has been a fan of the ramps for 10 years now. My little 3 is nothing to these ramps. Line them up.. don't overshoot and you'll be fine. No danger of collapsing at all. None.
1 - 20 of 26 Posts
