1 - 20 of 22 Posts
Need to know what wires coming out of the infotainment system are for the front two speakers for my subwoofer install.
I have the 2014 service manual from whoever posted it, but all the pages with the wiring diagrams are blank. I also have a feeling that the wiring may have changed slightly from the '14 to '15 because the standard sound system went from 4 to 6 speakers.
Any help is appreciated. Thanks.
Don't know if this will help then cause I have a '14 base stereo but the colors are LEFT Side: Light green +, Red -, RIGHT Side: Pink +, Green -. at the wire harness that plugs in the back of the radio.
On my Macbook the pages are blank and on windows I had to update Adobe Flash for the wiring diagrams to work.
there are two set of connectors are at the back of the unit one goes into a blue and one goes into a white. the one that goes into the blue one has a blue power wire and ground wire. i really need some help any pic of your install that will help me. my loc connect to the speaker wire so i need the correct colour code for 2014 mazda 3 and pic
Sorry I do have tweeters. Just to update this, I tied the line converter into the passenger side rear speaker and put the amp under the passenger seat. Wires are easily accessible by popping off the trim panel behind the seat belt. The passenger rear-door speaker wires were brown and light-blue so I assume the rest in your graphic are accurate for 2014-2016 as well.
A question, that is to connect a converter from high to low, I have to cut the cables that are to the right of my car (tuner and amp unit) and from there where can I get to connect the remote cable for an amplifier? 2R according to diagram?
Thanks since now !
not really all they did was tap the door speaker for the 2 dash “tweeters” tweeters have an inline crossover attached to tweeter’
yah same’ old thread maybe helps someone in future’
i bought pdf version on ebay for 10 bucks they utilize flash player it makes it a nightmare trying to enable it because flash is no longer supported as of this month’ so even windows updates disable it you’d think mazda would have used a better pdf
1 - 20 of 22 Posts
