Hi all:
Can you help me with this situation?
When I am listening to a radio station, the radio eventually jumps to the same station and remains stuck there for a varying amount of time before I can reset it to any other station. (This happens in both AM and FM, and the station the radio jumps to is in the same location on each tuning dial, for whatever that may mean.)
The time lapse from my setting a station to the radio moving to the other station varies, but it can be as little as a second or two. Today, it seemed that the screen beeped before the radio jumped stations. I am not sure it this has been happening during the week or so in which this has been going on.
Any help you can provide will be greatly appreciated!!
I’d try to disable alternative frequency (af) and traffic announcement (ta). Don’t see any other reason a working radio should switch frequencies for.
you may have a problem with the screen digitizer, ghost touches, run diagnostics to eliminate other parts.
Using commander switch
1. Switch the ignition to ACC or ON (engine off or on).
2. Press the following buttons simultaneously for 2 s or more.
Volume dial
AUDIO button
FAVORITES button
then type 3 ENTER and read DTC write the code or codes, post it here or google, type 2 ENTER to clear press EXIT
you could also try 4 CMU DTC diagnostics
be careful not to enter anything else
