How does Speedometer speed compare to real/GPS Speed?
  • GPS/real speed matches Speedo
    Votes: 8 42.1%
  • Speedo is low GPS/real speed is higher than Speedo
    Votes: 7 36.8%
  • Speedo is high GPS/real speed is lower than Speedo
    Votes: 4 21.1%
1 - 12 of 12 Posts
For 2014+ cars I'm curious if others are seeing the same that I see...
I'm running 205/55-16 and I like the change better than the 60 profile for handling/feel/ride and look... I've posted before on the speedo... here's how it was with the 2014 an 2018
I had a 2014 and now a 2018 when I change my tire size...
205-60/16 - Speedo 100km/h - GPS - 101 km/h
205-55/16 - Speedo 100km/h - GPS - 96/97 km/h
225-45/17 - Speedo 100km/h - GPS - 97 km/h
I found it quite surprising that the speedo reads low with stock size tires... rare as normally they show you 1/2km lower than actual. Really looks like they change from 205/55 to 205/60 without changing the speedo calibration. The 2012 we've got that comes with 205/55 stock reads the same as above...
Curious what others with are seeing with stock tire sizes... 206/60-16
With the OEM 205/60/16 Yokohamas, my '15 Mazda speedometer seems to report a slightly slower-than-actual speed, by one or two MPHs.
This is unusual for me, as normally the factory setup reads a bit faster-than-actual speed in the previous cars from the factory that I've owned. I always figured the factory wanted to keep from being blamed for speeding tickets or speed-related accidents, but Mazda doesn't seem concerned about that. :)
You have to get the circumference correct. Of course 205/55/16 will be off.
I'm going to downgrade from 18s to 16s. But I will put 225/55/16 and my speedo will be close enough.
Im asking about grip and handling diference 205 60 vs 215 55
Enviado desde mi G3123 mediante Tapatalk
If you get the same exact tire 205/60 vs 215/55 there won't be much difference.
If you go from a 205/60 all season to a 215/55 high performance all season or summer tire there will be a huge difference in favor of the 215/55. But if you get a 215/55 performance tire the ride might get slightly firmer.
It is hard to answer your question but if you hate the handling of the 205/60 you will probably be very happy with a 215/55 performance tire.
Bridgestone Ecopia 205/60/16
Speedo 70mph - GPS (garmin)- 70mph
Continental ts830p Winter
205 / 60 / r16 92H - Speedo 136 km/h - GPS - 130 km/h (84,50 mph / 80,78 mph)
Toyo ner38 Summer
205 / 60 / r16 92V - Speedo 134 km/h - GPS - 130 km/h (83,26 mph / 80,78 mph)
Michelin Primacy 4 Summer
205 / 55 / r16 94H XL - Speedo 138 km/h - GPS - 130 km/h (85,75 mph / 80,78 mph) <- this one is quite annoying
1 - 12 of 12 Posts
