Always loving speed and cars, why not put those two together? Narrowed it down and these 3 cars are awesome to my customers. But which is better in speed and other specifications? And how about those prices? The more info you have, the better.
Why a 2004 RX8 versus a 2011 RX8? Obviously if you can afford a 2014 Nissan 370z, you could afford the later RX8. Same logic applies to the GTI, why a 2010 when you can get a newer model?
In the case of the RX8, 2004 was the introduction year, so it had a few development bugs/TSBs/recalls that were solved in the later years. 2009 and up (series 2 RX8's) are the ones to get.
rotary. just the sound of one is amazing.
^This, especially if the exhaust is uncorked a bit.
I'd be looking at the 2014 Z purely because one would assume it would be in the best condition, I would stay away from the 2004 Rx8 as rotaries are expensive to fix, and aren't exactly what you'd call a reliable motor.
Nonsense - rotaries get an undeserved bad rep for reliability because of: (a) Clueless owners who are too damned lazy to read & heed the advice in the owner's manual, and (b) A less than competent service infrastructure being provided by Mazda dealerships - WAY too many RX8s and FDs had their engines unnecessarily replaced under warranty at dealerships simply because the Mazda techs didn't know what the hell they were doing.
well that's what rotaries are all about. most break down because people don't look after them well. but when you do take good care of it, that thing is rev happy all day long.
^This. The older rotaries (12A & 13B) N/A engines can often last well above 200K miles on average. A well-cared for turbo 13BT (FC, single turbo) or 13B-REW (FD, twin turbo) typically averages 100K~150K miles without need for a teardown. When a turbo motor dies, it's usually due to too much heat over time and/or being modded beyond the stock ECU/fuel system's ability to safely manage. The RX8 motor, although N/A, due to design changes to the ports, lube system and the fact that it runs a much higher compression than the older N/A rotaries is not as durable - they average about 150K miles before teardowns.
