I installed new Monroe (just oem) rear shocks on my 2010 Mazda 3 GT 5 door and the rear end is squeaky... sort of a rubber sound. It happens often and did not occur prior to installing the shocks.
I did not replace anything except the shocks. My mechanic replaced the shock mounts about 4 to 6 months ago so they are virtually brand new and he did rear trailing arm bushings and some other suspension things. I replaced the shocks because one started leaking on me the last couple weeks.
I torqued everything to I believe what was correct according to the service manual I have... 75 ft/lbs for the bottom bolt and about 20 or 21ft/lbs for the top bolts in the shock mount. Though to be fair my torque wrench while brand new is a cheap one.
Does anyone have any idea what could be causing the noise? Defective shock? Or the rubber cover/sleeve for the shock?
What should I do next? The car has 100k in the Northeast so I'm being very gentle with those top bolts for fear of breaking them. Fortunately they came off easy.
