1 - 20 of 20 Posts
Smells of Elderberries
I was surfing google for coilovers/ lowering springs struts and I ran across this info on the 2010 Prokit- PDF file attached
From what I can find on the 04-09 Prokit They haven't changed anything??? I'd almost bet they are the same springs re-boxed with a new part#
Mazda 3 04+
Pro-Kit:
Front 1.2 Rear 1.2
Spring Rate: (F) 160 (R) 171
Spring Type: Linear, Single Rate
LINK- Eibach Springs : NEWS : MAZDA 3 2010 - Pro-Kit
Front:
OE rate: 24 N/mm (137 lbs/in)
PK rate: 28 N/mm (160 lbs/in)
Tubing: Yes
Bump-stop: OE
Damper: OE
OE wheel center to fender: 385mm (15.2in)
PK wheel center to fender: 355mm (14.0in)
Pro-Kit can be aligned to OE alignment specifications.
Approximate installation time: 1.5 hr
REAR:
OE rate: 23 N/mm (131 lbs/in)
PK rate: 30 N/mm (171 lbs/in)
Tubing: None
Bump-stop: OE
Damper: OE
OE wheel center to fender: 384mm (15.1in)
PK wheel center to fender: 356mm (14.0in)
Reactions: Derrick_B
Hmmm. I had my suspicions!
Did you notice that the data shows that the spring rates are linear but their advertising says that they are progressive. Unless I'm interpreting it wrong.
Every Eibach Pro-Kit is designed and tested by our suspension
engineers and performance driving professionals, to deliver
aggressive good looks and high performance handling, without
ever compromising safety or ride quality. By using our
proprietary, progressive spring design, Pro-Kit provides the
ultimate balance to take your passion for driving to a whole
new level.
new level.
I noticed that too. thats also how they list the prokits for 04-09 too, but Sportlines are listed as progressive with two spring rates listed... Strange?! I was and still am under the assumption that pro-kits are progressive rate springs.
Pro-Kit
(Linear, single rate)
Front = 160#
Rear = 171#
SportLine
(Progressive, Dual rate)
Front = 97# / 280#
Rear = 114# / 303#
Now, does anyone know the spring rates on the Mazdaspeed's gen 1 and 2
Silver Demon
They'd have to be linear....otherwise I believe you'd have some deformation going on...Basic Hooke's law for materials. :001_unsure:
Discussion Starter #7
Left=Progressive_________ Right= Linear
Progressive are loosely wound on one end and tight on the other giving the spring 2 different characteristics/spring rates
Linear are evenly wound and compress at the same rate no matter
After living with my prokits for the last six months I think I'd like springs that are a little stiffer. I'd like to see some data on the new H&R before I commit to them. Megan Racing have a 250/250 rate with a 1.5" drop.
That seems to me that they would be ideal. I was considering Road Magnet but at 360/360 they seem to be too much like coilovers. They might be a little harsh.
Same here. After 2 days with them, I feel that they could do well to be stiffer as the ride is still too comfy! I want to be jarred on my daily drive, damnit!
Also, I would like maybe 1/2 finger more drop on the front and1.5 finger drop in the back. back still looks high to me.
Scratch the Megans. Not many people have good things to say about them. Maybe Tein s-tech. They look like higher quality. My prokits softened up alot. I liked them better when the bounced me around. I like them tight. LOL
Scratch the Megans. Not many people have good things to say about them. Maybe Tein s-tech. They look like higher quality. My prokits softened up alot. I liked them better when they bounced me around. I like them tight. LOL
If you think pro kits are too soft, s techs are not the way to go.
Got a better suggestion? PK's are 160/170 s-tech's are 163/240 .
Insert Witty Title Here..
That's what she said...
Silver Demon
So then they're pre-deformed to behave non-linearly...I see
Silver Demon
Double poster... lol:Michael_Jackson_dan
H&R /thread
I don't care what the rates are, I have had both and the S-techs left much to be desired on my WRX.
1 - 20 of 20 Posts
