Hello there!
I own a 2010 Mazda 3 with 110K miles. It's the 5 speed 2.0 version.
My Mazda 3 has started giving me some transmission issues. No error code. But here is what is happening.
1) Putting in reverse started not working. I have to try multiple times to succeed.
2) I added some fluid and after that it started working fine.
3) I came back after a 2 weeks trip and the issue restarted so I thought it was a leak. I added some fluid. Then I checked and it is OVERFILLED.
4) Now if you put in REVERSE or PARKING it does not engage.
5) I did figure out a trick: If after you put in R or P you push the lever UP like an eighth of an inch you hear a click and the transmission engages correctly.
Can I keep doing #5?
Do you think if I flush all the fluid and put new fluid it could help? And what fluid would you recommend?
If not what else could I do?
Thank you in advance!!
