1 - 16 of 16 Posts
Hey all I am new here and wanted to get your opinion on short shift plates, and also wanted to know if any one here is running the corksport ssp on their 2.5. Have any of you had any transmission issues? I have been running mine for a couple of weeks no grinding but I seep to hear the gear box more but that could be because of the solid shifter base bushings combined with the ssp. Please let me know what your opinion and or issues are thanks!
I feel like it is a bit of both most defiantly feel it more ? like I can hear the clicking into gears more pronounced after the bushing install? is this normal?
Also with the ssp I have adjusted the linkage and noticed that I had to pull the shifter to the right to get it less notchy
do you think a ssp is bad for the tranny I notice I have to use more force now to put it in gear and I have a light shift knob as well.
Discussion Starter #8
so what does the adjustment of the cables do? I noticed if i moved the adjustment so the shifter sits a little to the right the notchyness is gone and its short now but a little smoother.
it shifts fine its just a little notchy you can really feel the disengagement and engagement of each gear but left to right movement is super free and normal
Discussion Starter #13
do these plates in turn fuck up our transmissions if you are not slamming gears I kinda shift slow but try to make it smooth.
This plate won’t hurt your transaxle. It just moves the cable attachment point closer to the pivot point of the plate. This causes every action of the shift lever to make a larger movement at the transaxle, resulting in a shorter shifter throw. As a consequence, it does require more effort to make that action. It’s simply changing the leverage.
Discussion Starter #16
Awsome this is what I needed to know there is so much talk about them fucking up transmissions. Mainly I think it's driver error.
1 - 16 of 16 Posts
