My sons 2005 Mazda 3 just stopped shifting out of park.
I've tested these:
The horn does works
the brake lights do not work
the solenoid to release the shifter from park doesn't work.
Steps tried:
I replaced the brake light switch but no improvement.
The Brake light connector does have 12 volts to red.
After reading through several of the posts I am hoping it isn't the PJB. I'm hard pressed to guess where that wire goes from that connector at the brake pedal until it gets to a junction where it splits to the brake lights and the relay for the transmission interlock solenoid which sounds like it is in the PJB. Hoping someone has seen this issue or maybe has the pin out for the PJB connectors.
I've tested these:
The horn does works
Steps tried:
