Hope someone can help i bought a 2004 mazda 3 with 88,000 miles on it i test drove the car all was fine on the way home AT light came on and check engine light also. i pulled over turned car off and back on everything seemed normal started to drive and car would not shift passed 3rd brought car home plugged code reader and got code p0753 shift solenoid A malfunction got under car and see that previous owner hit something and transmission pan was dented took apart replaced oil pan and wire harness since wires were cut also replaced all solenoids and speed sensor and still having same problem hope someone can help ty in advance.
Are you still getting the same code after replacing those parts and is it still in Limp Home Mode (LHM) or different symptoms. If code is still present does it come back immediately after resetting?
Good Luck.
Classic symptoms of transmission control module (TCM) failure. Buy a refurb on eBay for $250 and swap it in yourself in 90 minutes or less.
