See my post here on a 2.5L running a CS CBE and cold air intake with airbox: http://mazda3revolution.com/forums/...81-corksport-cold-air-box-11.html#post2242338Considering the mazda3 but I can't find anything about the 2.5 #s . I can find info on the 2.0 and a few dynos but nothing about a bolt on tuned 2.5. can someone please help me find what to expect
Only 20 hp loss at the wheels is not bad. I've seen some 2.0l motors with as much as 35.:smile2:See my post here on a 2.5L running a CS CBE and cold air intake with airbox: http://mazda3revolution.com/forums/...81-corksport-cold-air-box-11.html#post2242338
Stock crank output is 184 and I've seen dyno runs at ~165 hp at the wheels.
I'll be updating post OVT tune as well.
Thank you for the link. 187hp/200tq no header with stock cat still?See my post here on a 2.5L running a CS CBE and cold air intake with airbox:
If you just buy aftermarket parts like intakes and exhausts there will be little gain without a tune. Aftermarket intake, exhaust, headers, etc. with a tune will make a noticeable difference in everyday driving.Just picked up a 2017 3S, manual trans. Doing the research on tuning and it seems that aftermarket intake and exhaust will add very little to performance.
Seems like either OV Tuning or DR tuning is the way to go and leave everything else factory? Your thoughts?
Are there any after market headers? I've seen ov and someone else make 2 different ones neither seems to have made it into production. No heads/cams or anything else correct?If you just buy aftermarket parts like intakes and exhausts there will be little gain without a tune. Aftermarket intake, exhaust, headers, etc. with a tune will make a noticeable difference in everyday driving.Just picked up a 2017 3S, manual trans. Doing the research on tuning and it seems that aftermarket intake and exhaust will add very little to performance.
Since the engine is tuned to operate on stock equipment, so a tune is needed to recalibrate for new flows in and out from intake and exhaust mods. If that makes sense.
However, being stock and tuned makes a difference as well.
Most of those aftermarket bolt-ons don't do much if anything at all. Even when tuned, whatever small bit of power they might provide isn't worth the hundreds of dollars they will cost. Most of the stuff is either cosmetic or done to change the sound of the car.Just picked up a 2017 3S, manual trans. Doing the research on tuning and it seems that aftermarket intake and exhaust will add very little to performance.
Not going to happen anytime soon sorry to say. The car already has a long tube header that works, and so far there haven't been any offerings that work better.Are there any after market headers? I've seen ov and someone else make 2 different ones neither seems to have made it into production. No heads/cams or anything else correct?
A decent tune can get a 2.0 Mazda 3 close to 180 hp at the crank, maybe a bit more depending on how well its done.I see some bolt ons and forced induction for the Miata making nice gains. Even a full exhaust + tune yielding 180hp/180tq.
Its a sexy looking long tube header
Technically speaking as long as any camshaft is not composite and is still machinable metal then cams are available for any engine.Cams are out there if you can find them. BBR I think is about the only real source.
A.
I am questionable that *XYZ did anything more then contract a cam grinder to do the work and the profiles for them and use proprietary rights investments and agreement contracts with them to call them their camshaft specifications. Trust me on this one! :nerd:Kamshaft said:Yes,
Sorry I think I was not very good at my last explanation?As I recall the issue was that billets could not be sourced in enough quantity to make it practical as most
That seems to be a good estimate for those mods. There was a header and cams floating around in the early years of the 3rd gen from OV but they've been discontinued because of manufacturing difficulties that OV had since he couldn't find someone to make them in limited quantities. Making small batches is very expensive, at least that's what my engineering design, manufacturing and materials class taught lol.So stock header back exhaust and sri and a tune is about max for the 2.5, but it sounds like plenty of power for me to avoid another civic si. Looking at around 180-190hp and 200ish tq?
And the 2.0 has few more bolt ons getting it around 180/180? Higher revs and a few lbs lighter
