My 2014 Hatchback is coming up on 100K miles. What maintenance things should I be looking to do at that time? My guess would be replace all fluids, spark plugs and air filter. Anything else that im not thinking of??
Auto tranny is lifetime fluid. But maybe. Mine still shifts smooth.
167k on my 2014 says otherwise. I do my oil every 15-20k, I did my plugs at 80k, coolant at 130k, my second set of rear brakes will be this weekend after 139k when the originals died at 27k. Nearly everything else original other than the tires, and the infotainment screen. Oh yea, the start stop battery started getting weak around 150k. Rather than face winter with it, someone bought it an x2 battery as an early christmas present.The idea that any vehicle fluid is good for the lifetime of a vehicle is marketing BS. Any engineer and transmission builder will explain how friction and particulates will reduce the viscosity of transmission fluid and oil. The idea of "lifetime" fluids is considered the average span of ownership and not the entire lifetime of the vehicle. I think a lot of it stems from the fact that people are sold another myth wherein if an automatic transmission has never been serviced that the fluid should not be changed, or else bad things will happen.
For the OP: You should get a copy of the service schedule and follow it regularly. Mazda is good about breaking up service intervals at 15K and 30K mile increments. One often overlooked item is the O2 sensors, which should be replaced anywhere from 60K - 75K miles.
I think the transmission filter needs to be replaced every 2 years or 30k miles167k on my 2014 says otherwise. I do my oil every 15-20k, I did my plugs at 80k, coolant at 130k, my second set of rear brakes will be this weekend after 139k when the originals died at 27k. Nearly everything else original other than the tires, and the infotainment screen. Oh yea, the start stop battery started getting weak around 150k. Rather than face winter with it, someone bought it an x2 battery as an early christmas present.
Not to say I'm not looking at swapping my fluid finally. But it probably won't be until 180k. I just don't have the budget for it. Food on the table, and wife's medical comes first.
Transmission filter isn't accessible. It's inside the pan which is sealed with RTV.I think the transmission filter needs to be replaced every 2 years or 30k miles
Changing a transmission filter (screen) is one of the messiest jobs you can do on a car. You generally get covered in spilt transmission oil with it's characteristic burnt caramel smell - don't wear good clothes.Transmission filter isn't accessible. It's inside the pan which is sealed with RTV.
If I drain the fluid, and it's not gritty, I'm not changing the filter.Changing a transmission filter (screen) is one of the messiest jobs you can do on a car. You generally get covered in spilt transmission oil with it's characteristic burnt caramel smell - don't wear good clothes.
New tranny oil is bright cherry red, degrades to a nutty brown and brownish black.If I drain the fluid, and it's not gritty, I'm not changing the filter.
Synthetic transmission fluid, I've found doesn't seem to breakdown like you describe. Just gets darker red.New tranny oil is bright cherry red, degrades to a nutty brown and brownish black.
50k Miles is the upper limit on fluid life, which get a sticky texture and the slimy metallic internal magnet.
You'll need sturdy plastic pry tools to remove the pan, gasket remover spray and gasket maker. The strainer filter is about $35 and a new tranny pan $45 (optional). YouTube has good videos of transmission pan removals.
I'd say changing the trans fluid is the messiest job you can do on a car bar none. I drive it onto a tarp, learned the hard way in the past.Changing a transmission filter (screen) is one of the messiest jobs you can do on a car. You generally get covered in spilt transmission oil with it's characteristic burnt caramel smell - don't wear good clothes.
You just described every transmission filter for an automatic transmission. Mazda uses RTV instead of a gasket, but that doesn't mean the filter can't be serviced.Transmission filter isn't accessible. It's inside the pan which is sealed with RTV.
You're just asking for trouble with that approach. Fine particulates do just as much damage as larger.If I drain the fluid, and it's not gritty, I'm not changing the filter.
Most transmission filters are more of a 50-100 micron screen than a traditional , say oil filter. I used to change them, but since they didn't trap much except rocks , I just change the fluid these daysYou just described every transmission filter for an automatic transmission. Mazda uses RTV instead of a gasket, but that doesn't mean the filter can't be serviced.
There's nothing wrong with this. They don't accumulate near the garbage they did in the past unless there's something seriously wrong. At that point you need a rebuild anyway.Most transmission filters are more of a 50-100 micron screen than a traditional , say oil filter. I used to change them, but since they didn't trap much except rocks , I just change the fluid these days
Good grief. If you're that deep into the job, change the filter! The pan has to be removed anyway. I want to say that I can't believe someone is so cheap (no, not frugal or smart) not to replace a filter in a piece of equipment that costs thousands of dollars to repair or replace.Most transmission filters are more of a 50-100 micron screen than a traditional , say oil filter. I used to change them, but since they didn't trap much except rocks , I just change the fluid these days
I change the fluid but I don't drop the pan- there are several ways of doing this. Don't see any point in changing a screen in a closed system, especially given the huge amount of mess associated with the filter change.Good grief. If you're that deep into the job, change the filter! The pan has to be removed anyway. I want to say that I can't believe someone is so cheap (no, not frugal or smart) not to replace a filter in a piece of equipment that costs thousands of dollars to repair or replace.
Wait a tick....is this one of those transmissions without a drain plug? I'm driving the manual so I honestly don't know.Good grief. If you're that deep into the job, change the filter! The pan has to be removed anyway. I want to say that I can't believe someone is so cheap (no, not frugal or smart) not to replace a filter in a piece of equipment that costs thousands of dollars to repair or replace.
